Les forums => Mécanique, Technique et Tuning => Discussion démarrée par: ferreret le Ven. 23 Déc. 2005, 00:36:59
Titre: kit 175 for a TW 125
Posté par: ferreret le Ven. 23 Déc. 2005, 00:36:59
Hello! I'm sorry but I don't speak French. I come from Mallorca and I speak spanish or catalan, and a little bit of english. Your web is very interesting, also in spain we don't have a website for the TW. I have a TW 125 type I, and I will upgrade to 175cm3. I buy this kit in www.bihr-racing.com. In this web, they offer the Wisseco(165cm3) and Wossner(140cm3) kit, and I decide for the Wisseco. But in the end, Bihr-racing, send to me a 175cm3 Wossner kit. I read a lot in your forum about the differents preparations, and seems the IP preparation. My mechanic is specialist in upgrade Harley Davidson, and he says that if the work is well done, I won't have problems(oil consumation!!). In 15th of January I will begin the work!! If somebody is interested, I will inform about the result.
Adeu! (Au revoir!)
Titre: Re: kit 175 for a TW 125
Posté par: yan le Ven. 23 Déc. 2005, 00:51:27
Welcome on board! I won't do my speech in spanish because I haven't talked for quite a while now! Of course, we are all very interested in your modification, and I'm pretty sure you won't be far from the TW200 performance!
Please keep us in touch, and if you can, try to take some photographs of the modification while it's being done. It can be the subject of a great article!
Hasta Luego  :-D
Posté par: ae91 le Ven. 23 Déc. 2005, 01:18:43
Welcome on this forum. And thanks by avance for all the remarks and informations concerning the modifications for the TW.
Sorry, but my English is not very good.
Merry Christmas has you and your family.
Posté par: macbig2k1 le Mar. 27 Déc. 2005, 22:59:29
This kit is for the xt125 and tw125.
If you have a xt125 engine, then you will have 175ccm and if you have a tw125 engine, then you will have 160ccm because the xt125 have a greater stroke but the same bore.
Posté par: ferreret le Ven. 03 Févr. 2006, 00:33:02
Hello another time!
Sorry about my english!!!
 I have news of the modification of my TW 125... Sorry, now is a TW 165. :-D  :-D . We make modifications also in "culasse", making bigger the admissions and exhaust, changing valves for news. For the moment I use the same carburator. I have done 70 km only, and the feeling is have more acceleration and power in low revolutions(in high I don't know. It's too much new!!). For an example, when I went in a mountain road, before I went with the 3 and 4 gear medium-full gas. Now I can go with 4 and 5 gear with 1/3 of gas. Now the acceleration comes in  a very low revolutions of motor, and it's more nervious (When I open a little of gas, goes up revolutions inmediatly). Another very different thing its the brake of the engine: when I cut the gas, the bike decrease the speed immediatly, similar when I went in the 3er gear in 125. In a few days I will go to the mechanic to correct carburation and change pinion(two point bigger) to increase speed.
I wish don't break the motor for a long time.
If you need some information, in my bad english I try to answer.
I'm sorry, I don't have pictures of modifications.
Salut! Adeu!
Posté par: nico-dem le Sam. 04 Févr. 2006, 22:56:18
christddel tu es l'encyclopedie vivante du forum , respect  ;-)
Posté par: Anonyme le Sam. 04 Févr. 2006, 23:59:21
salut christddel, une petite question a te poser :-D
As tu aussi changé ta carburation (gicleur, ou autre) quand tu es passé en 157cm3, ou un simple réglage suffit.
Et salut à tous :salu
Posté par: macbig2k1 le Dim. 05 Févr. 2006, 00:09:21
@ferreret
Your english is not bad, thank you for your impressions.
I hope my engine will run in the next view days.
Posté par: ferreret le Sam. 25 Mars 2006, 10:31:38
Hello every body!
If you remember, I did the modifications of the cilynder of Birth-Racing. I have finished the work. At the end, I use a 16 point of pinion with 51 point of "courone". I use the same box of air filter, with a the flex piece of TW200, and I use a Keihyn 30 carburateur. The results are lose a little bit of very low revolution power, but win more power in high revolutions. I before change the tires and I use the original tyres Brigstone of yamaha TW 125 type II, and the speed counter reduce the speed 5 km/h. Before in 125 cm3 with the new tyres, the top speed was 95 km/h, and now the top speed is 118 km/h. The speed cruising is 100-105 km/h, and the top speed in 4th gear is 95 km/h. The fuel consumation is the same than before: 4.58 liters for a 100 km in a mix city-road use!. And no oil consumation. I'm very happy  :-P  :-P
Posté par: Hog le Sam. 25 Mars 2006, 15:25:16
Bon dia ferreret.
Thanks again for the quite complete report you provided. It seems your bike is upgraded to a level that is pretty close to the TW 200 level.
Posté par: trive le Mer. 29 Mars 2006, 15:43:57
hello i'm from italy and i have a karion 125.
do you know if the kit works on karion?
thank you...
Posté par: ferreret le Mer. 29 Mars 2006, 16:14:07
Hello! There are many places of upgrade 125 cm3:
http://www.unlimited-power.net/
http://www.bihr-racing.com/
I buy my upgrade kit in bihr-racing, but now, I don't know why, they don't have it.
Good luck!
Posté par: macbig2k1 le Mer. 29 Mars 2006, 17:38:16
Here is a little Soundcheck in 2 qualities from my TW160.
768kBit/s (2,51MB) (http://www.htwm.de/~sweiss2/TW160-Gia-Sound-0.75Mbit.wmv)
2,1MBit/s (6,74MB) (http://www.htwm.de/~sweiss2/TW160-Gia-Sound-2.1Mbit.wmv)
I have my Kit from www.woessner-kolben.de (http://www.woessner-kolben.de)
Posté par: yan le Mer. 29 Mars 2006, 17:48:36
Lovely...
I cannot find anything for the TW on the Woessner website...
[ Edité par yan le 29/3/2006 17:54 ]
Posté par: macbig2k1 le Mer. 29 Mars 2006, 18:02:34
At the end of dec. '05 the 140 and 160-kit was it in the database.
But I'am sure that the bihr and unlimited are the same.
Posté par: yan le Mer. 29 Mars 2006, 18:05:44
Ok I'll have another look...
I'm more looking for a 250 kit
Posté par: macbig2k1 le Mer. 29 Mars 2006, 18:12:59
I think woessner can make a 250ccm-kit for you, if you have a TW200!
Posté par: yan le Mer. 29 Mars 2006, 18:58:31
Ok maybe I will contact them directly...
