Titre: macbig2k1 builts his own 5-valve-engine Posté par: macbig2k1 le Sam. 14 Févr. 2009, 04:16:14 Salut mes amis,
I decided last year to build my own engine for the TW. The base for "my" engine is the original gearing and gearbox (crankcase) from a TW125. And I will use as "Top End" the cylinder, cylinderhead and piston from a YZ/WR250F. The basic idea was a watercooler TW engine. I have now nearly all parts for the conversion. One thing is sad, the cylinderhead is without valves and springs. But I will not use the too expensive titanium valves (price for a set [5], over 500 EUR), I will install a fitting set steel valves with springs. A original Keihin carb is too expensive for me, I would have to pay 800-900EUR for it. I will use a cheaper Mikuni carb, but I don't know which one (at this time). I started the same topic in the US TW200-Forum (link) (http://tw200forum.com/forums/57815/ShowPost.aspx) and in our German TW125 forum (link) (http://www.tw125.de/index.php?mode=viewthread&forum_id=8&thread=188) to get more input (problems that I haven't seen). Here are some pictures: (http://img6.imageshack.us/img6/4325/parts1ze4.th.jpg) (http://img6.imageshack.us/img6/4325/parts1ze4.jpg) - YZ/WR250F cylinderhead (without valves and springs) - YZ/WR250F cylinder - 76mm std. sleeve (http://img6.imageshack.us/img6/7221/p2104271lo1.th.jpg) (http://img6.imageshack.us/img6/7221/p2104271lo1.jpg) The crankcase with the bigger bore for the 76mm sleeve. Thanks to christddel for the hint with a bigger sleeve. (http://img6.imageshack.us/img6/7881/p2104274fz5.th.jpg) (http://img6.imageshack.us/img6/7881/p2104274fz5.jpg) You can see here the difference between the YZ/WR250F and a TW200 cylinder. (http://img6.imageshack.us/img6/588/p2104275vn5.th.jpg) (http://img6.imageshack.us/img6/588/p2104275vn5.jpg) And now from the side. I know, the iron sleeve is too long. The sleeve will be cutted later to the correct length. (http://img4.imageshack.us/img4/8726/p2104276ex3.th.jpg) (http://img4.imageshack.us/img4/8726/p2104276ex3.jpg) You can see, the cylinder/sleeve fitts perfect into the crankcase. (http://img4.imageshack.us/img4/2802/p2114278ou3.th.jpg) (http://img4.imageshack.us/img4/2802/p2114278ou3.jpg) I have to close the internal oil pipe from the TW cylinder, because the WR/YZ250F cylinderhead does have a external oil pipe. (http://img3.imageshack.us/img3/2093/p2114279oq8.th.jpg) (http://img3.imageshack.us/img3/2093/p2114279oq8.jpg) A guy from the US forum asked "Do you have enouth space for the timing chain?" I think, this picture can show you very good, that it could fit very well. I know that the original clutch (4 or 5 disks, 4 springs) is not good enouth for this power. And I found the solution for this problem, it's the 7 disk and 5 spring clutch from a DT125 (max. 24hp). These bikes does have the same clutch: TDR125, TZR125 (max. 33hp), TZR150, DT200, WR200 (max. 31hp), SDR200, YFS200 (quad), DT230. I've ordered a special clutchset from EBC, it's a racing kit with all needed disks (friction and steel) and stronger springs. There are still a lot of things to do. My saying: "A problem doesn't exist, just a solution has not found." Titre: Re : macbig2k1 builts his own 5-valve-engine Posté par: nico-dem le Sam. 14 Févr. 2009, 08:44:13 little bit crazy but i'm sure that it will work ;)
Titre: Re : macbig2k1 builts his own 5-valve-engine Posté par: Namna le Sam. 14 Févr. 2009, 09:54:49 Il manque une possibilité de réponse :
"Cela devrait fonctionner" La course est-elle modifiée, ou gardes-tu l'embiellage standard ? Les points les plus délicats seront d'assurer le graissage et le refroidissement correct pour garantir la longévité. D'autre part, le CDI de la TW a-t'il les bonnes caractéristiques en terme d'avance à l'allumage ? En tous cas, c'est un beau projet, félicitations ;) Titre: Re : macbig2k1 builts his own 5-valve-engine Posté par: george-le-yeti le Sam. 14 Févr. 2009, 11:14:22 ouah ca va tiré sec !! ;D
Titre: Re : Re : macbig2k1 builts his own 5-valve-engine Posté par: T2vv le Sam. 14 Févr. 2009, 12:36:07 Il manque une possibilité de réponse : "Cela devrait fonctionner" La course est-elle modifiée, ou gardes-tu l'embiellage standard ? Les points les plus délicats seront d'assurer le graissage et le refroidissement correct pour garantir la longévité. D'autre part, le CDI de la TW a-t'il les bonnes caractéristiques en terme d'avance à l'allumage ? En tous cas, c'est un beau projet, félicitations ;) Cette possibilité de réponse ne manque pas puisque celà VA fonctionner... ;D De mémoire il me semble que l'on peut jouer sur l'avance a l'allumage, Christddel l'a fait il me semble quand il a modifier un arbre a came. :) Titre: Re : macbig2k1 builts his own 5-valve-engine Posté par: macbig2k1 le Sam. 14 Févr. 2009, 17:35:09 @ Christian
The solution for fixing and the cooling oulet from the cylinder is not so complicated. I will use a alu adapter plate with all needed holes and threads for the crankcase and cylinderhead and with the outlet for the hot water. 5mm for the timing/distribution chain?!? No problem, we can remove a bit from the crankcase (see marked area): (http://img11.imageshack.us/img11/8222/p2104280cg8.th.jpg) (http://img11.imageshack.us/img11/8222/p2104280cg8.jpg) And a solution for the waterpump is also found. I will install a pump on the generator side and the sprocked will be mounted on the rotor. My engine pro knows a very good company for carbon parts. Mybe they will make a new carbon generator cover with an integrated water pump. @ Namna > gardes-tu l'embiellage standard? qui, standard > le graissage Pas de souci. d'autres pignon pour pompe à huile > D'autre part, le CDI de la TW a-t'il les bonnes caractéristiques en terme d'avance à l'allumage? (http://tw200forum.tw-parts.com/images/smilies/icon_shr.gif) Titre: Re : macbig2k1 builts his own 5-valve-engine Posté par: Namna le Sam. 14 Févr. 2009, 18:33:55 Quelle cylindrée obtient-on avec ce cylindre et la course d'une 200 ?
Which cubic capacity do you obtain with this cylinder and the vilbrequin of TW 200 ? D'autre part, sur la photo, on dirait que les pignons d'arbre à came sont plus petits. Faut-il aussi changer le pignon sur le vilbrequin ? In addition, on the photograph, it seems that the pinions of camshaft are smaller. Is it also necessary to change the pinion on the vilbrequin ? |
