Sam. 23 Nov. 2024, 10:52:10
Suite modif 157 Cm³
Pages:
8
9
10
Fil de discussion: Suite modif 157 Cm³ (Lu 84874 fois)
macbig2k1
Re : Suite modif 157 Cm³
Répondre #135 le:
Jeu. 05 Mai 2011, 12:02:09 »
I have a question.
Is your compression pressure still at 15kg/cm²???
So.....
The TW125 engine:
12kg/cm² - compression pressure
-> 10:1 - compression ratio
Is this formula correct (based on the 125 engine??):
compression pressure = compression ratio * 1,2
The compression ratio from your engine will be 12,5:1
So, I've extended my engine performance table and I've added the compression ratio to the table.
TW-Parts.com
Le magasin en ligne fournisseur de pièces détachées pour Yamaha TW 125 - 200 - 225
The onlineshop with bike parts for the Yamaha TW 125 - 200 - 225
macbig2k1
Répondre #136 le:
Jeu. 05 Mai 2011, 12:33:00 »
OK......this calculation (compression pressure = compression ratio * 1,2) is wrong.
A other example:
Yamaha TW200
9kg/cm² - compression pressure
-> 9,5:1 - compression ratio
Yamaha YP250 Majesty
14kg/cm² - compression pressure
Yamaha YFM350 quad
8,5kg/cm² - compression pressure
-> 9,2:1 - compression ratio
Can you tell me the compr. ratio from your engine?
Or the value from your combustion chamber?
You're are using the std. con rod from the 225 with a 17mm piston pin bore? Right?
And you're using the 74mm piston from the 250 raptor?!? Or was it a different one?
TW-Parts.com
macbig2k1
Re : Re : Suite modif 157 Cm³
Répondre #137 le:
Ven. 06 Mai 2011, 16:22:36 »
Citation de: christddel le Ven. 06 Mai 2011, 00:47:37
La chambre de combustion (combustion chamber) fait 30 cm³
Compression Ratio normal devrait être ---> 259 : 30 =
8,63
There is a small mistake in your calculation:
epsilon -> compr. ratio
Vh = 259ccm
Vc = 30ccm
epsilon = (Vh + Vc) / Vc or = (Vh / Vc) + 1
epsilon = (259 / 30) + 1
epsilon = 9,63 : 1
TW-Parts.com
macbig2k1
Re : Re : Re : Re : Suite modif 157 Cm³
Répondre #138 le:
Ven. 06 Mai 2011, 21:24:31 »
Citation de: christddel le Ven. 06 Mai 2011, 20:43:02
So if (Donc si...) 124 cm³ , Ration 10:1 = 12Kg cm²
With kit 165, even combustion chamber 125...
Avec Kit 165 même chambre de combustion 125...
163 cm³, Ratio 12,83 = 15kg/cm²
On a 15 kg/cm³ de pression de compression..
15 kg/cm³, That's what I measure on my TW 157 cc
15 kg/cm³, C'est ce que je mesure sur ma TW 157 cm³
OK, it could fit. Based on the calculation.
But, 12,83:1 is realy high.
TW-Parts.com
macbig2k1
Répondre #139 le:
Ven. 06 Mai 2011, 22:00:16 »
And here is the table.
TW-Parts.com
TW Mk IV - W650 - Dax 125
Répondre #140 le:
Ven. 17 Juin 2011, 23:18:46 »
Oh mais ça théorise grave ici !
Je vois que vous n'êtes pas resté les 2 pieds dans le même sabot comme on dit chez moi...
Alors christddel : il tourne ce moteur ou il est en conception ?
Grosse prime pour le premier qui arrive à 350 cc !!
Répondre #141 le:
Sam. 18 Juin 2011, 00:11:24 »
Je plaisantais, mais déjà 260 c'est fort
Et je constate que tu as déjà gagné 100cc par rapport au titre
Merci de défricher ce terrain : ça pourra toujours servir un jour !
skai
TW 125 TYPE 1 -1999- 16500 KMS !!!!!
Répondre #142 le:
Sam. 18 Juin 2011, 18:48:22 »
Citation de: christddel le Sam. 18 Juin 2011, 00:04:15
350cc avec une base moteur de TW, n'est pas réalisable...
Le moteur 259 est encore au stade de ré-assemblage...
Il avait trop de compression, j'ai du redémonter le cylindre 4 ou 5 fois, pour modifier la hauteur de la culasse (entretoise & chaine distr + longue)
et j'ai endommagé un segment lors d'un des remontages ( un nouveau jeu de segments est arrivé -achat USA- )
Un 300
,2
cc est aussi un de mes proto en cours... Avec vilebrequin 64,5mm de course et piston 77 mm d'alésage.
Salut à toi , c'est incroyable ce que tu fait
, je veut voir des video , tu en à pas mis sur youtube ou autres
merci de me tenir au jus , j'adore !
ROULEZ EN TIWI , C'EST PROFITEZ DE LA VIE
Uploaded with
ImageShack.us
skai
Re : Re : Re : Re : Re : Suite modif 157 Cm³
Répondre #143 le:
Sam. 18 Juin 2011, 23:08:12 »
Citation de: christddel le Sam. 18 Juin 2011, 22:02:53
J'ai mis des vidéos sur
"ImageShak"
pour en voir d'autres, vas sur << Précédent ou suivant>>
ok , merci.
Uploaded with
ImageShack.us
Répondre #144 le:
Sam. 06 Août 2011, 05:07:58 »
Bravo bien joué
bonne route v+
https://picasaweb.google.com/nico.dem06/BWD8StLaurentLesBains?authkey=Gv1sRgCKbp2sHk-_yy6wE
Pages:
8
9
10
