Auteur Fil de discussion: valve clearences?  (Lu 3373 fois)
snailofsatan
« le: Mar. 08 Mai 2007, 23:14:27 »
hello! excuse my english! but you seem to know and like TW125s here!!
i have a technical question which hopefully you will know the answer...
my brother is fixing my 2003 tw1215 and has the following questions to complete it:
Do you know the valve clearances in mm or 100ths of an inch? (or anything)
and is there one setting for inlet valve and one for exhaust?
(or are they the same clearance?)
and how tight to tighten the headbolts (torque setting)?
thanks in advance for you help :)
any help is much appreciated!!!!!
kev.
snailofsatan
« Répondre #1 le: Mar. 08 Mai 2007, 23:21:25 »
ooh, i've just found the valve clearances on your site!!
http://yamaha.tw.free.fr/jeu_soupapes_tw.htm
just need to find the torque settings for the head bolts now :)
i knew i should have come here!!!
macbig2k1
« Répondre #2 le: Mar. 08 Mai 2007, 23:44:53 »
Please take a look on my site http://www.macbig2k1.de.vu
klick - "Videos und Dokumente für die TW (videos and documents for the TW)"
scroll down to "Wartungsanleitung (repair manual)", this is the english version.
[ Geändert von macbig2k1 an 08.05.2007 23:46 ]
« Répondre #3 le: Mer. 09 Mai 2007, 10:41:08 »
I had to adjust the exhaust and admission valves clearance several times but I didn't care much about the torque. I'd say "not too much" or "moderate" is enough.
macbig2k1
« Répondre #4 le: Mer. 09 Mai 2007, 10:55:56 »
Hog schrieb:
...I'd say "not too much" or "moderate" is enough.
And you can use middle strong screw glue.
« Répondre #5 le: Mer. 09 Mai 2007, 12:06:34 »
Indeed ... And it's quite easy to check the headbolts tightening by removing the cover.
