Auteur Fil de discussion: TW125/TW200 - Dynojet Perfomance Test  (Lu 20790 fois)
macbig2k1
« le: Dim. 17 Août 2008, 04:20:42 »
Hello,
I made today (Saturday) some tests with a friend and his TW125 and my TW200 on a Dynojet Performace test stand (banc d'essai/banc d'épreuve).
The tested bikes:
Test 1
Bike: Yamaha TW125
Type: DE01
Engine: 125ccm
Modifications: -----
Test 2
Bike: Yamaha TW125
Type: DE01
Engine: 125ccm
Modifications: Giannelli exhaust (nearly identical with the G.P.R. exhaust)
Test 3 (my bike)
Bike: Yamaha TW125
Type: DE01
Engine: 200ccm (cylinderhead, cylinder, crankshaft)
Modifications: high compression piston, Mikuni VM28-418, bigger outlet, YZ450F exhaust
Test 4 (from a Yamaha cataloge)
Bike: Yamaha TW200
Engine: 200ccm
Modifications: ---
picture download big - 2303 x 1807
picture download middle - 1150 x 902
picture download small - 800 x 628
And here are the results:
Test 1
Bike: Yamaha TW125
Max. power: 11,42 PS/CH
Test 2
Bike: Yamaha TW125 with Giannelli exhaust
Max. power: 11,28 PS/CH
Test 3 (my bike)
Bike: Yamaha TW125@200ccm
Max. power: 18,90 PS/CH
Bike: Yamaha TW200
Engine: 200ccm
Max. power: 16 PS/CH
You see, for the TW200 ~3PS/CH more power (with still 200 ccm) with a high compression piston (from 9,5:1 to 10,25:1), the Mikuni flatside carb and a optimised outlet.
My Mikuni is not perfect adjusted, the mixture is a bit too rich (too much fuel). I had some missfire on the test stand.
I will add soon some pictures from the test's.
Questions?
Salut, Sebastian
george-le-yeti
« Répondre #1 le: Dim. 17 Août 2008, 08:50:45 »
Yeah right man !!  Choqué
george-le-yeti
« Répondre #2 le: Dim. 24 Août 2008, 20:24:27 »
gianelli suck
macbig2k1
« Répondre #3 le: Dim. 24 Août 2008, 21:58:38 »
Why?
Just the max. performance is just 0,1kW (= 0,14 PS/CH) lower. But the performace is in the lower rpm 0,4-0,8kW (= 0,54-1,09 PS/CH) higher as with the org. exhaust.
Take a look on the Nm (just the TW125)
picture download big - 2303 x 1355
picture download middle - 1150 x 677
picture download small - 800 x 471
The results:
Test 1
Bike: Yamaha TW125
Max. torque: 0,8 kgm = 7,848 Nm
Test 2
Max. torque: 0,82 kgm = 8,044 Nm
Max. raise torque: +0,19 kgm = +1,864 Nm -> +13%
Result: Giannelli does not suck!
You have to look on the complete rpm range, not just the max performance. You will have compareable results with all the other exhaust systems on the market.
Taitai
OUGL !
« Répondre #4 le: Lun. 25 Août 2008, 12:13:08 »
Thanks a lot, Mac ! Very interresting to have some real tests, not just reports based on the driver's sensations...
The modifications you made on your 200 ccm are just using quality/performing parts without changing the ccm ? Do you think possible to have gain just by changing the piston and exhaust, and enlarge the exhaust valve hole ? What is the risk with the original breech when using a high compression piston ?
Don't hesitate, if you can make some comparative tests it's very interresting ! Keep in touch... Clin d'oeil
« Répondre #5 le: Lun. 25 Août 2008, 13:02:07 »
Là on sent le mec qui va avoir un peu plus de temps pour bidouiller sa TW  Grimaçant
« Répondre #6 le: Lun. 25 Août 2008, 13:17:24 »
Là on sent le mec qui va avoir un peu plus de temps pour bidouiller sa TW  Grima&ccedil;ant
j'dirais plutot que ça sent le démontage vu qu'il a une brele de remplacement  Clin d'oeil , n'est - il pas ?
« Répondre #7 le: Lun. 25 Août 2008, 13:43:54 »
les deux en fait , y va la perfectionné et la bichonner sa tite 200 Souriant ésperont .
La brelle de remplacement est quand même très pratique pour pouvoir passer du temps sur sa tiwie. y'en a qui on de la chance d'avoir plusieurs brelle , même qui en a qui en on plus de deux.... Souriant
« Dernière édition: Lun. 25 Août 2008, 13:47:48 par warnours » Journalisée
Taitai
OUGL !
« Répondre #8 le: Lun. 25 Août 2008, 14:06:20 »
Zut, ça s'est vu ?!  Grima&ccedil;ant
macbig2k1
« Répondre #9 le: Lun. 25 Août 2008, 17:05:32 »
Hmm...not realy.
It's always the time after the work or the weekend. Not to have a girlfriend saves time Cool Grima&ccedil;ant
The ccm upgrade was very small (from 196,4 to 199,3), because I use the 67,5mm piston, because the cylinder was very old.
A 10,25:1 compression isn't very high, if you compare it with a YZ450 with a 12,5:1 compression.
I made just these (for the engine important) changes:
- open airbox (http://yamaha.tw.free.fr/filtre_boite_air_tw.htm#boite)
- Mikuni VM28-418 (kit: 125_VM28_1)
- 10,25:1 piston
- bigger outlet
- open exhaust
-> That is everything
My engine works fine, no problems.
stepf321
« Répondre #10 le: Sam. 30 Août 2008, 17:45:15 »
Heuuuu...! comment dire , A oui je parle pas anglais, Hé oui c'est un site Français ICI, Hein ?
C'est dommage, parceque je serai intéréssé par la sujet.
« Répondre #11 le: Sam. 30 Août 2008, 20:26:37 »
Disons que lorsque des Tiwistes allemands ont des choses à expliquer, ils préfèrent le faire en anglais qu'en allemand.
Quelle partie t'intéresse, que l'on puisse te la traduire (enfin si on y arrive, parce que les courbes de couple, ce n'est pas trop mon fort  Grima&ccedil;ant )?
5star
« Répondre #12 le: Lun. 01 Sept. 2008, 23:09:14 »
Christddel cést un vrais specialiste  pas seulement en mecanno !
Christddel  is een echte specialist niet enkel in de mekaniek !
george-le-yeti
« Répondre #13 le: Mar. 02 Sept. 2008, 14:07:54 »
Sorry for the mistake Macbig, I thougth test1 is with Ginaelli.. It's wrong sorry.
Gianelli is better.
macbig2k1
« Répondre #14 le: Mar. 02 Sept. 2008, 14:44:56 »
It's OK.
