macbig2k1
« le: Dim. 17 Août 2008, 04:20:42 » |
Hello, I made today (Saturday) some tests with a friend and his TW125 and my TW200 on a Dynojet Performace test stand (banc d'essai/banc d'épreuve). The tested bikes:Test 1 Bike: Yamaha TW125 Type: DE01 Engine: 125ccm Modifications: ----- Test 2 Bike: Yamaha TW125 Type: DE01 Engine: 125ccm Modifications: Giannelli exhaust (nearly identical with the G.P.R. exhaust) Test 3 (my bike) Bike: Yamaha TW125 Type: DE01 Engine: 200ccm (cylinderhead, cylinder, crankshaft) Modifications: high compression piston, Mikuni VM28-418, bigger outlet, YZ450F exhaust Test 4 (from a Yamaha cataloge) Bike: Yamaha TW200 Engine: 200ccm Modifications: --- picture download big - 2303 x 1807picture download middle - 1150 x 902picture download small - 800 x 628And here are the results:Test 1 Bike: Yamaha TW125 Max. power: 11,42 PS/CH Test 2 Bike: Yamaha TW125 with Giannelli exhaust Max. power: 11,28 PS/CH Test 3 (my bike) Bike: Yamaha TW125@200ccm Max. power: 18,90 PS/CH Test 4 (from a Yamaha cataloge) Bike: Yamaha TW200 Engine: 200ccm Max. power: 16 PS/CH You see, for the TW200 ~3PS/CH more power (with still 200 ccm) with a high compression piston (from 9,5:1 to 10,25:1), the Mikuni flatside carb and a optimised outlet. My Mikuni is not perfect adjusted, the mixture is a bit too rich (too much fuel). I had some missfire on the test stand. I will add soon some pictures from the test's. Questions? Salut, Sebastian
george-le-yeti
« Répondre #1 le: Dim. 17 Août 2008, 08:50:45 » |
Yeah right man !!
george-le-yeti
« Répondre #2 le: Dim. 24 Août 2008, 20:24:27 » |
gianelli suck
macbig2k1
« Répondre #3 le: Dim. 24 Août 2008, 21:58:38 » |
Why? Just the max. performance is just 0,1kW (= 0,14 PS/CH) lower. But the performace is in the lower rpm 0,4-0,8kW (= 0,54-1,09 PS/CH) higher as with the org. exhaust. Take a look on the Nm (just the TW125) picture download big - 2303 x 1355picture download middle - 1150 x 677picture download small - 800 x 471The results:Test 1 Bike: Yamaha TW125 Max. torque: 0,8 kgm = 7,848 Nm Test 2 Bike: Yamaha TW125 with Giannelli exhaust Max. torque: 0,82 kgm = 8,044 Nm Max. raise torque: +0,19 kgm = +1,864 Nm -> +13%Result: Giannelli does not suck!You have to look on the complete rpm range, not just the max performance. You will have compareable results with all the other exhaust systems on the market.
Taitai
OUGL !
« Répondre #4 le: Lun. 25 Août 2008, 12:13:08 » |
Thanks a lot, Mac ! Very interresting to have some real tests, not just reports based on the driver's sensations... The modifications you made on your 200 ccm are just using quality/performing parts without changing the ccm ? Do you think possible to have gain just by changing the piston and exhaust, and enlarge the exhaust valve hole ? What is the risk with the original breech when using a high compression piston ? Don't hesitate, if you can make some comparative tests it's very interresting ! Keep in touch...
« Répondre #5 le: Lun. 25 Août 2008, 13:02:07 » |
Don't hesitate, if you can make some comparative tests it's very interresting ! Keep in touch... Là on sent le mec qui va avoir un peu plus de temps pour bidouiller sa TW
« Répondre #6 le: Lun. 25 Août 2008, 13:17:24 » |
Là on sent le mec qui va avoir un peu plus de temps pour bidouiller sa TW j'dirais plutot que ça sent le démontage vu qu'il a une brele de remplacement , n'est - il pas ?
« Répondre #7 le: Lun. 25 Août 2008, 13:43:54 » |
Là on sent le mec qui va avoir un peu plus de temps pour bidouiller sa TW j'dirais plutot que ça sent le démontage vu qu'il a une brele de remplacement , n'est - il pas ? les deux en fait , y va la perfectionné et la bichonner sa tite 200 ésperont . La brelle de remplacement est quand même très pratique pour pouvoir passer du temps sur sa tiwie. y'en a qui on de la chance d'avoir plusieurs brelle , même qui en a qui en on plus de deux....
« Dernière édition: Lun. 25 Août 2008, 13:47:48 par warnours »
Taitai
OUGL !
« Répondre #8 le: Lun. 25 Août 2008, 14:06:20 » |
Là on sent le mec qui va avoir un peu plus de temps pour bidouiller sa TW Zut, ça s'est vu ?!
macbig2k1
« Répondre #9 le: Lun. 25 Août 2008, 17:05:32 » |
Là on sent le mec qui va avoir un peu plus de temps pour bidouiller sa TW Hmm...not realy. It's always the time after the work or the weekend. Not to have a girlfriend saves time Thanks a lot, Mac ! Very interresting to have some real tests, not just reports based on the driver's sensations... The modifications you made on your 200 ccm are just using quality/performing parts without changing the ccm ? Do you think possible to have gain just by changing the piston and exhaust, and enlarge the exhaust valve hole ? What is the risk with the original breech when using a high compression piston ? Don't hesitate, if you can make some comparative tests it's very interresting ! Keep in touch... The ccm upgrade was very small (from 196,4 to 199,3), because I use the 67,5mm piston, because the cylinder was very old. A 10,25:1 compression isn't very high, if you compare it with a YZ450 with a 12,5:1 compression. I made just these (for the engine important) changes: - open airbox ( http://yamaha.tw.free.fr/filtre_boite_air_tw.htm#boite) - Mikuni VM28-418 (kit: 125_VM28_1) - 10,25:1 piston - bigger outlet - open exhaust -> That is everything My engine works fine, no problems.
stepf321
« Répondre #10 le: Sam. 30 Août 2008, 17:45:15 » |
Heuuuu...! comment dire , A oui je parle pas anglais, Hé oui c'est un site Français ICI, Hein ? C'est dommage, parceque je serai intéréssé par la sujet.
« Répondre #11 le: Sam. 30 Août 2008, 20:26:37 » |
Disons que lorsque des Tiwistes allemands ont des choses à expliquer, ils préfèrent le faire en anglais qu'en allemand. Quelle partie t'intéresse, que l'on puisse te la traduire (enfin si on y arrive, parce que les courbes de couple, ce n'est pas trop mon fort )?
5star
« Répondre #12 le: Lun. 01 Sept. 2008, 23:09:14 » |
Christddel cést un vrais specialiste pas seulement en mecanno ! Christddel is een echte specialist niet enkel in de mekaniek !
george-le-yeti
« Répondre #13 le: Mar. 02 Sept. 2008, 14:07:54 » |
Sorry for the mistake Macbig, I thougth test1 is with Ginaelli.. It's wrong sorry. Gianelli is better.
macbig2k1
« Répondre #14 le: Mar. 02 Sept. 2008, 14:44:56 » |
It's OK.
