Auteur Fil de discussion: Need some carb measurements  (Lu 2465 fois)
macbig2k1
TW125@233ccm(SM) TW125@250ccm(MX) MZ Mastiff660
« le: Jeu. 01 Janv. 2009, 23:15:19 »
Hi,
I want to add some K&N filters to my shop, but I need the measurement from the carb.
I need the outer diameter from the carb intake from:
- the TW200 with drum brake (latest 2000)
- the TW200 with disk brake (first 2001).
-> Both bikes should have different diameters (something around 42mm), because the part numbers are different (5LB and 2JX). <-
- the TW125 type II with round headlight (should be ~45mm, but I am not sure)
Thanks, Sebastian
macbig2k1
« Répondre #1 le: Dim. 04 Janv. 2009, 01:01:22 »
Thank you, now I need just the measurements from the other carbs.
