sinophilia
« Répondre #15 le: Sam. 15 Mai 2004, 10:58:36 » |
Thank you everybody, the job is actually very easy, you just need to buy the necessary nuts and bolts. As for the third support, I think I will use a flat aluminum strip so I can bend it as I like... distance between the two attachment points is short so it should be strong enough to just keep the headlight in place, even if it's flexible. I'll let you know. Have a nice week-end!
Francky
« Répondre #16 le: Sam. 15 Mai 2004, 15:20:44 » |
Did you remove the black metal frame that currently held the original headlight ? Where do you plan to attach the third point, to the existing point (below the square headlight) on the fork support where the black metal frame was attached ? Thanks for your support.
sinophilia
« Répondre #17 le: Sam. 15 Mai 2004, 16:19:40 » |
Yes to both questions, Francky. Anyway, today I rode for about an hour across the city, with peak speeds of 80 km/h, and neither headlight nor windshield moved a bit. Only thing I noticed, is that the headlight glass was steaming hot when I finally stopped... was the old one too? I didn't notice...
Well, for a few kms I found myself together with a group of "gros cubes" (Monster, Hornet, CBF600) and I swear, little TW didn't look out of place! ;-)
« Répondre #18 le: Lun. 17 Mai 2004, 11:46:27 » |
Diana,
Yes glass of the headlight, on the original model, is also very hot, nothing worrying. :-)
sinophilia
« Répondre #19 le: Lun. 17 Mai 2004, 15:06:15 » |
ok, thank you! :-)
One more test yesterday: riding in two. As you know, the light beam rises a lot with two persons... the old headlight wasn't very bright so this didn't disturb anybody, but this one is really dazzling! So I decided to lean it down a little, even more than needed.
Hier j'ai fait un autre essai: monter en duo. Comme vous savez, le faisceau lumineux s'élève beaucoup avec deux personnes... le vieux phare n'était pas très lumineux ainsi n'a pas dérangé quiconque, mais celui-ci brille vraiment beaucop! Ainsi j'ai décidé de pencher le un peu vers le bas, encore plus que nécessaire. [Google translation edited, is it understandable?!?]
« Répondre #20 le: Lun. 17 Mai 2004, 15:29:46 » |
sinophilia a écrit : [Google translation edited, is it understandable?!?]
Very fine ! It's nearly fluent french !
Olox
« Répondre #21 le: Jeu. 20 Mai 2004, 09:42:36 » |
Grazie mille Diana for your explanation ! It's a while we were waiting for such article ! I just put a link on the site. I'll translate it later. By the way your website is really classy. Ciao
sinophilia
« Répondre #22 le: Jeu. 20 Mai 2004, 16:47:43 » |
Thank you Olox! Actually I started building that website for myself, to put my TW pictures in order, and to learn how to use Dreamweaver (I had never used a composer before). But I had free space at my webhost so in the end I published it... ;-)
Olox
« Répondre #23 le: Ven. 21 Mai 2004, 16:20:56 » |
Is your headlight this one ?  10033992 HAUPTSCHEINWERFER SCHW. SEITL.BEFESTIGUNG 180MM 69,95
Olox
« Répondre #24 le: Ven. 21 Mai 2004, 16:28:01 » |
Next challenges: Old skool: Ultimate:
sinophilia
« Répondre #25 le: Ven. 21 Mai 2004, 16:47:30 » |
Yes!
« Répondre #26 le: Sam. 22 Mai 2004, 09:38:03 » |
pour le modèle old skool c'est HOG qui va être content et pour l'ultimate eh bah c'est moi , olox tu pourrais nous avoir les prix des jolis p'tites lumières que tu nous as trouvés et sur quel site ,marci bocou
« Répondre #27 le: Dim. 23 Mai 2004, 13:13:12 » |
Le gros est magnifique !!!!!! Celui de Diana aussi. Quand j'aurais mon TiWi, je ne mettrais pas longtemps à craquer........ ! :hammer:
« Répondre #28 le: Dim. 23 Mai 2004, 20:19:57 » |
Milwatt
« Répondre #29 le: Dim. 23 Mai 2004, 23:11:49 » |
C'est mon banquier qui va faire la gueule ! :-P
