Pages: 1 [2] 3  Toutes   Bas de page
Auteur Fil de discussion: Phare rond: grand finale!  (Lu 14335 fois)
sinophilia
« Répondre #15 le: Sam. 15 Mai 2004, 10:58:36 »
Thank you everybody,
the job is actually very easy, you just need to buy the necessary nuts and bolts.
As for the third support, I think I will use a flat aluminum strip so I can bend it as I like... distance between the two attachment points is short so it should be strong enough to just keep the headlight in place, even if it's flexible.
I'll let you know.
Have a nice week-end!
Francky
« Répondre #16 le: Sam. 15 Mai 2004, 15:20:44 »
Did you remove the black metal frame that currently held the original headlight ?
Where do you plan to attach the third point, to the existing point (below the square headlight) on the fork support where the black metal frame was attached ?
Thanks for your support.
sinophilia
« Répondre #17 le: Sam. 15 Mai 2004, 16:19:40 »
Yes to both questions, Francky.
Anyway, today I rode for about an hour across the city, with peak speeds of 80 km/h, and neither headlight nor windshield moved a bit.
Only thing I noticed, is that the headlight glass was steaming hot when I finally stopped... was the old one too? I didn't notice...
Well, for a few kms I found myself together with a group of "gros cubes" (Monster, Hornet, CBF600) and I swear, little TW didn't look out of place! ;-)
En ligne En ligne
« Répondre #18 le: Lun. 17 Mai 2004, 11:46:27 »
Diana,
Yes glass of the headlight, on the original model, is also very hot, nothing worrying.  :-)
sinophilia
« Répondre #19 le: Lun. 17 Mai 2004, 15:06:15 »
ok, thank you! :-)
One more test yesterday: riding in two.
As you know, the light beam rises a lot with two persons... the old headlight wasn't very bright so this didn't disturb anybody, but this one is really dazzling! So I decided to lean it down a little, even more than needed.
Hier j'ai fait un autre essai:  monter en duo.  Comme vous savez, le faisceau lumineux s'élève beaucoup avec deux personnes... le vieux phare n'était pas très lumineux ainsi n'a pas dérangé quiconque, mais celui-ci brille vraiment beaucop!  Ainsi j'ai décidé de pencher le un peu vers le bas, encore plus que nécessaire.
[Google translation edited, is it understandable?!?]
TWin
Modérateur
« Répondre #20 le: Lun. 17 Mai 2004, 15:29:46 »
Very fine ! It's nearly fluent french !
Olox
Modérateur
« Répondre #21 le: Jeu. 20 Mai 2004, 09:42:36 »
The page about replacing the headlight will be at the following URL,
in case Olox wants to link or translate/summarize it in his site:
http://www.sinophilia.org/diana/tw/headlight.htm
Grazie mille Diana for your explanation !
It's a while we were waiting for such article !
I just put a link on the site. I'll translate it later.
By the way your website is really classy.
Ciao
sinophilia
« Répondre #22 le: Jeu. 20 Mai 2004, 16:47:43 »
Thank you Olox!
Actually I started building that website for myself, to put my TW pictures in order, and to learn how to use Dreamweaver (I had never used a composer before). But I had free space at my webhost so in the end I published it... ;-)
Olox
Modérateur
« Répondre #23 le: Ven. 21 Mai 2004, 16:20:56 »
Is your headlight this one ?
10033992 HAUPTSCHEINWERFER SCHW.
SEITL.BEFESTIGUNG 180MM
 69,95
Olox
Modérateur
« Répondre #24 le: Ven. 21 Mai 2004, 16:28:01 »
Next challenges:
Old skool:
Ultimate:
sinophilia
« Répondre #25 le: Ven. 21 Mai 2004, 16:47:30 »
Yes!
« Répondre #26 le: Sam. 22 Mai 2004, 09:38:03 »
pour le modèle old skool c'est HOG qui va être content et pour l'ultimate eh bah c'est moi , olox tu pourrais nous avoir les prix des jolis p'tites lumières que tu nous as trouvés et sur quel site ,marci bocou
Anonyme
« Répondre #27 le: Dim. 23 Mai 2004, 13:13:12 »
Le gros est magnifique !!!!!!
Celui de Diana aussi. Quand j'aurais mon TiWi, je ne mettrais pas longtemps à craquer........ ! :hammer:
En ligne En ligne
« Répondre #28 le: Dim. 23 Mai 2004, 20:19:57 »
Pour avoir plus d'info il faut aller ici:
http://www.evamotor.nl/Daytona/daytona_japan_special_parts_for3.htm
Milwatt
« Répondre #29 le: Dim. 23 Mai 2004, 23:11:49 »
C'est mon banquier qui va faire la gueule !  :-P
Pages: 1 [2] 3  Toutes   Haut de page
