Auteur Fil de discussion: [Vends] Upgradekit for TW125 from to 200 ccm  (Lu 13825 fois)
macbig2k1
« le: Dim. 01 Déc. 2013, 01:05:09 »
I've cleaned up a bit my storage and I've found a complete conversion kit from 125 to 200 ccm.
This kit includes:
- cylinder head with optimized combustion chamber, new valves and new cam bearing (ball bearing, better as the alu sleeve)
- 200 ccm cylinder with a new 68 mm Wiseco piston with increased compression 10.5:1
- 200 ccm crankshaft with 55.7 mm stroke
- complete top end gasket kit (o-rings are installed)
Condition of the parts
- complete rebuild cylinder head, close to a new one (new valves, gaskets, bearing)
- no question, the cylinder is like new -> now bore + new piston = complete new
- crankshaft with bearings and con rod is absolute OK, everything is in spec
The price list:
150,00 EUR - cylinder head
120,00 EUR - crank shaft 55,7mm
120,00 EUR - cylinder 67,0mm
45,48 EUR - cylinder hone up to 0,5mm oversize
123,39 EUR (instead of 145,58 EUR) - Wiseco 68,0mm (BIHR-4292P4)
46,08 EUR (instead of 55,82 EUR) - TKRJ valve kit (GS-YY0300_1300a)
2,71 EUR (instead of 4,17 EUR) - spark plug NGK DR8EA
5,30 EUR (instead of 6,91 EUR) - cam shaft ball bearing (SKF 6005)
66,70 EUR (instead of 72,26 EUR) - top end gasket kit
0,00 EUR (instead of 60,00 EUR) - optimized combustion chamber
0,00 EUR (instead of 14,00 EUR) - grinding in the valves
0,00 EUR (instead of 60,00 EUR) - disassemble and assemble of the complete cylinderhead
0,00 EUR (instead of 5,90 EUR) - shipping by DHL (5,90 is for Germany)
-> !!!!free shipping inside of Europe!!!! <-
-> !!!!only 20,00 EUR for world wide shipping!!!!<-
679,67 EUR (instead of 860,12 EUR) - total
-> 180,45 EUR saved
If you want, you can also get:
21,82 EUR (instead of 28,85 EUR) - new timing chain (Mat-7413040)
5,60 EUR (instead of 7,46 EUR) - oil filter (HF143)
250,97 EUR (instead of 272,59 EUR) - 28 mm Mikuni flatside carb kit for DE01 (TWP-125_VM28_DE01)
221,01 EUR (statt 238,15 EUR) - 28 mm Mikuni flatside carb kit for DE05 (TWP-125_VM28_DE05)
IMPORTANT:
These prices are fixed. Some prices are now strong reduced and a lot of my working time is for free.
This is an good priced offer for the European market.
So, get it.
The parts are ready to ship.
When I get the payment, I will try to send the parts at the same day.
Best regards,
Sebastian
josouzo
« Répondre #1 le: Jeu. 13 Mars 2025, 21:04:02 »
Hello, im 12 years late, i wish i discovered bikes at this time.
  Ind&eacute;ci
Sofiane from Bordeaux.
